Blu ray Burner | How to Burn Blu ray from Videos Free
2020-10-27 05:00:57     Posted by Starry
2058
Summary: Seeking the best Blu ray burner helps you burn and convert your favorite digital video files to HD Blu-ray movies for better playback on home theater system. This article aims to give you a full picture of four best Blu ray burners that enable you to make your own Blu-rays playable on home Blu-ray player and media player software, and how to burn Blu ray with the most professional Blu ray Burner.
What is the best Blu ray burner software? With the advent of Blu ray and increasing popularity of home theater, numerous people are inclined to watch Blu rays on standalone Blu ray players compatible with large screen HD TV displays. However, it is an undisputable fact that Blu-ray movies come at a price. It’s not that easy to purchase and collect all released Blu-ray films. In the long run, it is cost-efficient to make your own Blu-rays from HD video files, which drives the emergence of Blu ray burner. Hence, to look for a professional Blu ray burner means a lot if you intend to watch quality home-made Blu-rays. Read on to figure out why these recommended Blu ray burners are really the best and can better suit your needs.
1. Regular Types of Blu ray Burner
What is exactly a Blu ray Burner? In a narrow sense, Blu ray burner refers to the hardware that enables you to write/etch or burn data onto to Blu-ray discs. Nowadays Blu-ray burner also means all sorts of Blu ray burning software that can burn digital data onto Blu-ray discs, save them as Blu ray ISO image files or Blu ray folders. In this sense, Blu-ray burner falls into three kinds: external Blu ray burner, Blu ray burning software, and internal Blu ray burner. Here are three typical examples of each kind of Blu ray burner.
Best External Blu ray Burner
As we know not every laptop or desktop computers are loaded with all additional features or capabilities. Thus, you might need to use USB ports to collect the UDB Blu ray burner, powerful disc drives to compensate storage limitations. Likewise, an external Blu ray burner, also called writer-reader combination optical drive, has gained the wind since it works as a standard external Blu ray drive, allowing for writing data content to a Blu ray disk, or watching Blu ray content on a computer. Typical of the best external Blu ray burner is LG BE16NU50 External Blu ray Burner (Writer & 3D Blu ray disc Playback). LG Blu ray Burner precedes other options like Pioneer Blu ray Burner, due to its advanced features.
Best Blu-ray Burner Software
Currently, DVDFab DVD Creator fully deserves the title of best Blu ray burner software that has been a rising star based on its constant innovations and improvements in data backup solution and its dedication to stunning user experience. The detailed features of this best Blu ray burner will be discussed below.
Best Internal Blu ray Burner
Though Blu ray discs resemble DVDs, the former have a narrower laser beam spot and shorter wavelength, thus holding more content than the latter. Usually, before buying an internal Blu ray burner drive, you shall check first whether your PC or laptop has necessary slot that enables you to place the Blu ray drive. Then go and pick out the best internal Blu ray burner that stands out in the aspects of system compatibility, storage capacity, disc type, writing speed, supported disc and read, compatible port, cable and software driver, supported surround sound format, and other additional features. A good example is ASUS BW-16D1HT, the best internal Blu ray burner with M-DISC support for lifetime data backup and storage. Of course, you can choose other Blu ray DVD burner if you hope to burn Blu ray and DVD at the same time.
2. Comparison of Best 4 Blu ray Burners You Need to Know
Since most external/internal Blu ray burners are not that affordable and look cumbersome, lots of users tend to choose Blu ray burner software to proceed with data backup. To save you time looking for the best Blu ray burning software on Google, the following table will give you a better clue to which one you shall select.
Items
DVDFab Blu-ray Creator
Leawo Blu-ray Creator
Aiseesoft Blu ray Creator
Xilisoft Blu ray Creator
Price
$42.9 (tax included); 30-day free/full trial
$39.95
$31.96
$49.95
Available OS
Windows & Mac
Windows & Mac
Windows
Windows
Input Video Format
MKV, MP4, AVI, M2TS, TS, MOV, WMV, 3GP, FLV, M4V, VOB, etc.
AVI, MP4, DAT, WEBM, RMVB, RM, MPG, MPEG, VOB, MOV, M4V, FLV, F4V, MKV etc.
TS, M2TS, TP, TRP, MPG, MPEG, M4V, MP4, VOB, WMV, MXF, etc.
AVI, MPEG, WMV, MP4, MKV, MPG, MTS, M2TS, TS, DivX, H.264/AVC, XviD, VOB, MOV, QT, RM, RMVB, FLV, 3GP, 3G2, ASF, DV, DAT, NSV
Output BD
BD-R/RE, BD-50, BD-25, BD-9, BD-5 (AVCHD DVD), Blu-ray ISO/Folder
BD-25, BD-50, DVD-5, DVD-9, Blu-ray ISO
BD-25, BD-50, Blu-ray folder or ISO file
BD-R, BD-RE, BD-25, BD-50, DVD-9, DVD-5, AVCHD ISO, BDMV ISO
Menu Templates
Static & dynamic BD-J menu templates; custom settings for elements and widgets; regular update
Menu templates for various themes; custom settings
Menu templates of different themes with editable buttons
Menus of different themes with editable buttons
GPU Hardware Acceleration
Multi-core CPU, Intel Quick Sync, NVIDIA CUDA, batch conversion and lightning-fast burning speed
Intel Quick Sync for fast processing speed
Batch conversion
 NVIDIA CUDA for fast conversion speed
Customized Options
Advanced settings for volume label, output size, video quality, playback mode; audio tracks, subtitles; font, size, and color for menu settings, customize background (snapshot)
2D video to 3D Blu-ray/DVD; internal video editor (trim, crop, effect, watermark, brightness, contrast, saturation, volume zoom); add subtitles
Set video encode, frame rate, bitrate, audio channel; add audio track and subtitles;
Video editing (crop, trim, watermarks, add subtitles/audio track, special effects, brightness, contrast, saturation)
Output BD Quality
BD-50/25 1080p,
BD-9 1080p, BD-9 720p, BD-5 1080p, BD-5 720p
1280x720p, 1440x1080p, 1440x1080i, 1920x1080i, 1920x1080p
User Interface
Clean, intuitive, friendly
Clean, simple
Blu-ray Drive Needed
Yes
Yes
Yes
Yes
Preview & Snapshot
Yes
Yes
Yes
This table makes a clear comparison of top 4 best Blu ray burner software that have had a place in the marketplace, each of which has its own master card. Whichever you choose depends on your affordable price, user demand and conversion speed. Just choose the one that suits you best.
3. How to Burn Blu ray Movie Easily with DVDFab Blu-ray Creator
See from above, DVDFab DVD Creator surpasses other alternatives via its fast conversion speed and peak quality. With this best Blu ray burner, all kinds of video formats captured from HD camcorders, iPhone MOV videos, common SD videos, in diverse video formats can be converted into BD or AVCHD DVD for better playback on home Blu-ray player, HDTV displays, superb game consoles, and media player software.
Now let’s look at how to burn Blu ray movies with fast speed and premium quality with DVDFab Blu ray Burner.
Step 1: Launch DVDFab Blu ray Burner and load video source
Download, run DVDFab 11 (where DVDFab DVD Creator is integrated with other modules for the sake of better user experience), choose Creator module when the program runs. Load the videos (of various formats you like) to burn digital video files onto BD discs/ISO files/folders or AVCHD discs.
Step 2: Customize output Blu ray movie
Hit the Advanced Settings button to choose Volume Label, Output Size (BD-25, BD-50, BD-5, BD-9), Video Quality, and Playback Mode. Meanwhile, you can choose your desired Audio Track, add Subtitles to the videos to make your Blu ray movie personalized.
Then go to the Set Menu and selected your favorite Blu ray menu template. Here you are allowed to add image or text to the menu, adjust font, size, color of subtitles and playback control button. All the menu templates will be updated regularly. Of course, you can design your own Blu ray movie menus with the built-in features of this Blu ray Burner software.
Step 3: Start to burn Blu ray movies with the Blu ray burner
Insert a blank Blu-ray disc into the external Blu-ray drive if you want to burn Blu ray disc. Alternatively, choose to save the output Blu ray movie as ISO image file or movie folder. Once done, press the striking Start button to activate the process of burning Blu ray. The whole real-time conversion and burning progress will be displayed. Above all, GPU hardware acceleration technologies will be activated to quicken the conversion process with lightning-fast speed and excellent quality.
Remember to locate your converted Blu ray from the movie folder on your PC’s HDD. Besides, a triangle icon next to the Folder icon will pop up once the burning task is completed, which means you can play your self-made Blu-ray movie with the best 4k Blu ray player, DVDFab Player 6.
Note that DVDFab Blu-ray Burner acts as free Blu ray burning software once you try it within 30 days before your final subscription.
Final Thought
Now you have gained a better understanding of types of Blu ray disc burner, top 4 best Blu ray burners, and how to burn Blu ray with the best Blu ray burning software, DVDFab Blu ray Burner. Next time when you want to make personal Blu-ray movies, do not forget to seek the best professional Blu-ray movie maker with menu support. Also, if you want to make a DVD movie for other use, feel free to try out DVD Creator.
1. Convert Blu-rays to AAC, MP3, MP4, MKV, M2TS, and etc.
2. Support all the popular smartphones, tablets, PDAs, and etc.
3. Freely customize the output audio & video parameters
You May Need Other Tools
DVDFab Player 6 Ultra
Best 4k media player for all DVD/Blu-ray/4K Utra HD Blu-ray/HEVC/regular video playback
DVDFab Toolkit
Most versatile multimedia editor to edit video, audio, image, and subtitles
DVDFab Enlarger AI
World's best AI-driven video enhancer able to upscale video from 480p to 1080p, or from 1080p to 4k
