Rip Blu ray to MKV/MP4/AVI on Laptop/iPhone/Mac
2020-10-27 04:49:11     Posted by WiKi
3947
Summary: Rip Blu ray to MKV/MP4/AVI on Windows/Mac/iPHone. Are you a frequent visitor to Netflix or are there terrific Blu ray movies you like? If you want to rip Blu ray Windows 10 or Mac instead of "watch Blu rayn English movies online free", read this article and choose a Blu ray burner Mac/Windows based on your needs.
What are the options for ripping Blu-ray on a Mac? The same goes for ripping Blu ray on Windows 10/8/7/XP, even on iPhone? Here are the favorable solutions for you to make a digital backup copy of Blu ray disc, folder and ISO image files.
1. How to Rip Blu ray Disc/DVDs/Movies
There are so many Blu ray videos streaming on Netflix like House of Cards and Daredevil, do you want to copy them? Seeing hills of Blu ray discs at home, have you ever thought of burning them to save more space? No matter what kind of reasons motivating you to make a digital backup copy of Blu rays, it is possible for you to do that. And the source can be a Blu-ray disc, a Blu ray folder or Blu-ray ISO file. Accordingly, you can output your Blu-rays in the three forms with the best Blu ray copy software for free.
2. How to Decrypt Blu ray Protection
In order to protect illegal Blu ray copy especially for commercial use, there are numerous kinds of protection embedded in Blu-ray movies. If you want to clone a Blu ray movie for personal use, how to decrypt Blu ray protection like AACS, BD+, BD-Live, UOPs, CCL, Cinavia, BD-J, Region Code, etc? Give this task to DVDFab Blu-ray Copy and it will recognize each protection and remove it automatically. When there is a need to remove Cinavia watermark in Blu-ray files, DVDFab Cinavia Removal will also help together.
3. How to Rip Blu ray to PC/Hard Drive/USB/iTunes/iPhone
Till now, extensive Blu ray copy ripping software can work on Windows, Mac, Linux, but none of them is compatible to iPhone, Android, less than a flash drive or something like this. To watch your Blu ray to some portable devices like iPad/NAS, you need to copy it first on your PC or laptop, and then transfer the Blu-ray using a USB cable.
But, how about copying Blu rays to hard drive directly. In the first part, I have mentioned that DVDFab Blu ray copy software provides three paths to output your Blu-rays, including a disc, folder and ISO file. Then choosing the first destination and your Blu ray will be saved to a hard drive.
4. How to Rip Blu ray to MKV/MP4/AVI
Although you can transfer a Blu ray file from your PC to iPhone, there is another bar stopping you from playing it. That is incompatible format. Different from Windows, Mac and laptop, there are not so many formats supported in smartphones. So how to make ripped Blu rays also available on your mobile device like iPhone and iPad? The right way is to rip your Blu ray to MKV, MP4, AVI and any other video or audio format supported by your device.
Then what is the difference between Blu ray copy and Blu ray ripping? Let me give you an example. Suppose your iPhone is only able to play MP4 videos, while your copied Blu ray is output in the format of AVI. To convert AVI to MP4, you have to ask for DVDFab Video Converter for help after copying your Blu ray movie with DVDFab Blu ray Copy. Then, is there a straight way to copy Blu ray to AVI? YES. DVDFab DVD Ripper is capable to do that.
5. How to Rip Blu ray to DVD/UHD
Using DVDFab Blu ray Copy, you can burn Blu ray movies to any blank Blu ray discs like BD-25, BD-RE 25, BD-R 50. Similar to that you can also copy Blu-ray to a DVD disc like DVD+R/RW, DVD-R/RW, DVD+R DL and DVD-R DL. In term of price, Blu-ray disc is more expensive than DVDs. So to save money, it is a good option to burn Blu-ray to DVD.
Then how to copy Blu ray to UHD, making your video resolution increase further? To find the best answer to this problem, remember there is an “Enlarger AI” option empowered by artificial intelligence in DVDFab Blu ray Copy. Now follow me to explore how to burn Blu ray to UHD.
Steps on how to copy Blu-ray to UHD
• Download and install DVDFab 11
• Select the module of “Copy” on the top
• Import your Blu ray disc/folder/ISO file
• Choose one copy mode according to your need as listed below
• Enable the function of “Enlarger AI” on the same interface
• Click the “Wrench Icon” to choose a BD style and its resolution
• Set where to save your copied Blu ray file
• Tap the button of “Start” at the bottom
 i  Mac
Note: There are five modes DVDFab Blu ray Copy supports.
         Full Disc: copy the whole DVD disc.
         Main Movie: copy the main movie title.
         Customize: copy DVDs based on personal style.
         Merge: merge two or more DVDs to one.
         Clone/Burn: copy DVDs without a loss of quality
6. Top 3 Blu ray Copy & Top 3 Blu ray Ripper
It is easy to copy Blu ray movies with the assistance of powerful Blu ray copy software. Here, I will list 3 programs for your choice. Among them, DVDFab DVD Copy distinguishes itself by the features of “Enlarger AI” which can enhance video quality to 1080p or even 4320p.
(1) DVDFab Blu-ray Copy
• Compatible with Windows and Mac
• Price: Free version(30 days)/Paid version ($64.9 lifetime)
• Input: Blu ray disc/folder/ISO file as the source
• Decrypt Blu ray protection: AACS, BD+, BD-Live, UOPs, CCL, Cinavia, BD-J, Region Code, etc.
• 5 copy modes: Full Disc, Main Movie, Customize, Merge, Clone/Burn
• Output Blu-ray to a disc/folder/ISO file
• Quality: flawlessly with metadata copy including subtitle and audio tracks
• Copy Blu ray to any format of file with help of DVDFab Video Converter for free
• Upscale videos while copying (empowered by AI)
• Copy Blu ray 10X faster and easy to use
 i  Windows
(2) Leawo Blu-ray Copy
• Free Blu ray ripper Windows 10 and Mac
• Price: $44.95
• Decrypt Blu ray protection: AACS, BD+, MKB, CSS-DVD, Region restriction
• 3 copy modes: Full Movie, Main Movie, Custom Mode
• Carry out 1:1 Blu-ray clone
• Burn Blu ray disc/Folder/ISO image to Blu ray/DVD disc
• Copy speed: 6X faster
(3) Blu-ray Master
• Compatibility: Free Blu ray ripper Windows 10/8/7/Vista/XP
• Free Download or Pay for its service
• Copy Blu ray disc/folder to Blu ray disc/ISO image files
• 2 copy modes: Main Movie, Full Disc
• Make a digital back up of Blu rays in 1:1
• Speed: 6X faster than the normal speed
Afterwards, I will introduce top 3 Blu ray rippers for you. You can use any of them to directly rip Blu rays to MP4, MKV, etc., and enjoy Blu-ray movies on portable devices.
(4) DVDFab Blu-ray Ripper
Free Blu ray ripper Windows 10 and Mac, competent to rip 2D/3D Blu rays (disc/folder/ISO) to popular 2D/3D formats of videos, including H.265 videos. Similar to DVDFab Blu-ray copy, this free software also allows you to enhance video copy while ripping your Blu-ray movies. Now, let’s see how to use it.
• Download and Install DVDFab 11
• Choose the module of “Ripper” first
• Load your Blu ray file to DVDFab Blu-ray Ripper
• Click the the “Profile Switcher” below to choose your preferred video format
• Click “Enlarger AI” if you want to enhance your video copy
• Set the output folder and click “Start” at the bottom
(5) HandBrake
Handbrake is also a good Blu ray ripper which can be installed on Windows, Mac and Linux. But for beginners, this software is not recommended as you may spend lot of time researching how to use it. Besides that, it only rips your Blu ray movies to MKV and MP4 formats. What if such two video formats are not matched with your mobile devices? Apart from HandBrake, MakeMKV is also compatible with Windows, Mac and Linux, but it rips Blu rays to the format of MKV only. In comparison with DVDFab Blu-ray ripper, video formats HandBrake and MakeMKV support are less. And MakeMKV can merely decrypt AACS and BD+ protection.
(6) VideoSolo BD-DVD Ripper
VideoSolo BD-DVD Ripper is also among the top recommendations. As a professional DVD ripper, it is totally competent for such tasks and can give you a satisfying result.
• Price: $34.95
• Decrypt Blu ray region code
• Rip Blu ray DVD to 3D mode
• Output multiple video formats like AVI, MKV, MP4
• Offer built-in video editor, enabling you to add watermark and video effect
Have you decided to copy or rip Blu ray movies for offline reviewing? After making a decision, using the Blu ray copy and Blu ray ripper software from DVDFab I have recommended. There is a belief that you can enjoy Blu ray movies at your leisure and have a pleasant watching experience. For more information about how to copy Blu-ray to DVD, read another article in detail.
1. Convert Blu-rays to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract Blu-ray audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab DVD Copy
Copy DVD to a computer or a blank disc.
StreamFab YouTube Downloader Pro
Download videos from 1000+ websites at top speed.
Convert one video format to another based on your preference.
