How to Convert ISO to MKV Free & Easily
2021-09-06 04:17:32     Posted by WiKi
18975
Summary: Convert iso to MKV in batches. Are you looking for a handy iso to mkv converter that enables you to convert ISO files to MKV for better play on multiple mobile devices? This post offers a one-stop solution to convert Bluray/DVD iso to mkv. Read on for more details.
Why convert ISO to MKV? How do I convert ISO to MKV? All these problems will be resolved in this post. ISO files are quite common nowadays but they can often be difficult to play and share since they are not natively supported by a lot of multimedia players. Therefore, it's a good idea to convert ISO to a more widely supported format instead of finding an ISO player. Converting ISO files to a digital format like MKV has two benefits. First, you won’t have to worry about compatibility issues ever again. Second, MKV format keeps videos in high definition and often in small size. Then how to convert ISO to MKV free and easily? Continue to read and find the best ISO to MKV converter.
{{DIRECTORY}}
Part 1: Why Convert ISO to MKV?
How to convert iso to MKV? Before ISO to MKV conversion, let's learn about what is ISO file first? An ISO file is essentially an archive that contains all the files that would be written on a particular disc. That is why most of the time ISO files are also referred to as disc images. ISO files first appeared during the age of the CD but nowadays you’re more likely to see them on DVD and Blu-ray discs. So,"convert iso to MKV" is to convert DVD or Blu-ray disc to the MKV format. ISO Files are usually packed because a single archive is slightly smaller in size and easier to work with than multiple files and folders. However, the downside is that you will need a specialized tool to extract the files from the archive, or in the case of a DVD/Blu-ray movie, a specialized player. Of course, you could also just convert ISO to MKV instead.
Why convert ISO to MKV rather than other formats? Is there any benefit for iso to MKV? MKV is a very popular multimedia container that can hold a variety of different videos, images, audio tracks, subtitles, and more. Because of this, MKV files are perfect for storing movies and TV shows. A great feature of this format is that it can support almost any audio and video format regardless of its quality. In other words, "convert iso to MKV" is for MKVs can support a high-resolution Blu-ray movie just as well as a low-quality homemade video. The MKV format is highly adaptive and was designed with longevity in mind, which is why converting ISO to MKV is so popular.
Up to now, you have figured out ISO vs MKV, namely the differences between the two file formats. Now it's imperative to find out how to convert iso to MKV on macOS or Windows. Move on to the next part.
Part 2: How to Convert ISO to MKV on Mac/Windows
Now let's get down to how to convert ISO to MKV with the best ISO to MKV converter. The first two tools we want to recommend are DVDFab DVD Ripper and DVDFab Blu ray Ripper. These are different ISO to MKV freeware but work pretty much the same and allow users to rip the contents of any file or folder, DVD, or Blu-ray disc and convert them to MKV or other different formats. If you want to rip 4K UHD to 4K/SDR MKV etc., there is DVDFab UHD Ripper.
Regardless of which ISO to MKV converter you choose to convert ISO to MKV, they all support a wide variety of different output formats and offer a powerful MKV editor.  With any of them, you can convert ISO to MKV Mac free or rip ISO to MKV Windows free. Next, let me give you an example of how to convert a regular Blu-ray ISO to MKV. After grasping the skills, you can use the same method to convert UHD Bluray and DVD ISO to MKV.
Step 1: Launch DVDFab 12 and add ISO file
Free download the open-source DVDFab 12, the best MKV batch converter, and select the Ripper module to get started. Insert the disc you want to rip into your optical drive or use the navigation buttons to add an ISO file or folder if you want to rip and convert ISO to MKV that’s already stored on your computer. This best ISO to MKV converter supports batch conversion, so you can import multiple ISO files here.
 i  Free Download    i  Free Download
Step 2: Choose output profile
Profile Switcher aims to facilitate ISO to MKV conversion. The software automatically recognizes the type of ISO you want to rip (DVD, Blu-ray, or UHD Blu-ray)automatically. Considering you want to convert ISO to MKV, go to the Profile Switcher > Format > General > MKV. If you're going to convert ISO to other formats like MP4, AVI other than MKV, choose others based on your needs.
Warm tips: If you want to convert DVD/Blu-ray ISO to MKV files while upscaling video resolution, you are advised to trigger the Enlarger AI icon. That being said, once you click the Enlarger AI and choose MKV.AI as the output format, you will convert DVD ISO to MKV in 1080p or change Blu-ray ISO to MKV in 4K. How fantastic! This is the best way to upscale video while converting ISO to MKV for better quality.
Step 3: Customize output video
Before initiating the ISO to MKV conversion we’re going to spend a few moments checking out some of the editing options. On the main interface of DVDFab Ripper, there are two video editing tools, namely, Advanced Settings and Video Edit. The first menu will let you modify things like video quality, frame rate, resolution, encoding method, and more. Meanwhile, the Video Edit menu contains tools that let you crop and trim the video or add subtitles and watermarks. Other options like picking audio tracks and selecting specific chapters or titles are found on the main menu. Keep in mind that a few of the options differ depending on what type of ISO you’re trying to rip. For example, the options you see when you convert a DVD ISO to MKV will be a bit different from converting a UHD Blu-ray to ISO.
Step 4: Start to convert ISO to MKV file
Before clicking the button of Start to convert ISO to MKV, decide where to save the file by using the Save to the menu at the bottom.  It’s worth noting that Blu-rays take longer to rip than DVDs as they tend to be much larger in size. But the speed is still 10 times faster than the normal speed.
This article has discussed more about ISO and MKV formats in general, especially demonstrate how to convert ISO to MKV  free and easily. All the rippers discussed are professional tools and are guaranteed to work as advertised. What's more, you can use any of such rippers for free to initiate ISO to MKV conversion and edit it based on your personal needs. In a nutshell, the above-mentioned DVD/Bluray ISO to MKV converters are worth your full trial. Anyway, if you want to convert ISO to MKV format without upscaling video quality or converting to other formats, you can try another MakeMKV ISO to MKV converter. But it has limited features.
If you look for how to convert ISO to MP4 for old DVD movie discs, you can turn to the most powerful DVD Ripper, DVDFab DVD Ripper.
1. Convert Blu-rays to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract Blu-ray audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab Enlarger AI
Upscale video from 480p to 1080p, or from 1080p to 4K with AI
DVDFab Blu-ray to UHD Converter
Upconvert Blu-rays to standard 4K Ultra HD Blu-rays for better view
DVDFab Player 6 Ultra
Play DVDs, Blu-rays, (4K UHD) Blu-rays, 3D, HEVC, and other formats
