One-stop Solution to Rip Blu-ray to iPhone Easily
2020-10-27 05:05:56     Posted by Starry
6852
Summary: With the prevailing winds of streaming video, numerous people are inclined to watch videos online. However, they normally have to endure endless ads and buffering due to business benefit and network limitations. Considering this, DVDFab Blu-ray Ripper offers a perfect solution to rip Blu-ray to iPhone, or say to rip a Blu-ray to play movies on iPhone.
Want to rip Blu-ray to iPhone and enjoy converted movies wherever you are? Despite the fact that numerous movie lovers enjoy owning a physical disk, they need to purchase a specific Blu-ray disc player or install for media player app when they want to watch movies. Just put yourself in their shoes. If you prefer to play movies on iPhone rather than watch them on a cumbersome home player. What can you do? Is there any good solution to rip Blu-ray to iPhone free and easily? Solutions here! This article tells you how to rip Blu-ray movies to MP4 that can be playable on iPhone via iTunes with the aid of a powerful ripping software, DVDFab Blu-ray Ripper.
Part One: Blu-ray vs DVD
With the increasing innovation of digital media tech, Blu-ray seems to have won the high definition format war due to its advantages in storage capacity, laser technology, data transfer, resolution, etc. compared with that of DVD. The following screenshot will help you gain a better understanding of the detailed differences between them.
Part Two: Why Choose DVDFab Blu-ray Ripper to Rip Blu-ray to iPhone
Against the backdrop of the increasing popularity of Blu-ray and constant innovation of smartphones, a number of people are prone to convert Blu-ray to iPhone in order to watch videos on iPhone whenever and wherever possible. It is a coincidence that DVDFab Blu-ray Ripper has a perfect one-stop solution regarding how to rip Blu-rays to watch on iPhone based on its development of distinctive features.
First, DVDFab Blu-ray Ripper can read all sorts of Blu-ray discs, ISO image files, and folders, ripping and converting them to any mainstream audio formats, 2D and 3D video forms, further to portable devices that are in support of video playback.
Second, it allows users to customize the output video with its advanced settings and built-in video editor, which allows users to make certain modifications in accordance with personal preferences.
In addition, DVDFab Blu-ray Ripper is able to fix and apply the metadata info of the sources to the resulting video in the process of conversion.
Apparently, this product is really worth your try in contrast with similar software, since it offers a 30-day trial, free version, and paid version, not limited to its outstanding features.
Part Three: How to Rip Blu-ray to iPhone
Based on its unique features, DVDFab Blu-ray Ripper is necessary for you to master how to rip Blu-rays to iPhone. The following simple steps might lead you to a satisfactory output video that can be playable on iPhone (11/Pro/Pro Max).
Step 1: Launch DVDFab Blu-ray Ripper and load source Blu-ray
Download, install, and further run DVDFab 11. Choose the Ripper module from the upper option bar. Insert Blu-ray disc into the optical drive of your Mac or PC.
   i  Free Download                   i Free Download
Alternatively, Navigate it through the ‘+Add’ button on the main UI. On the other hand, drag and drop Blu-ray folder or ISOs to the ‘+’ button that is located in the center of the operation window.
Step 2: select a profile and customize output video
Tab switch profile to choose the device (iPhone) and output format (mp4) from the left panel.
Next, click ‘Advanced Settings’ (the wrench icon or inverted triangle situated in the upper right corner) to select your wanted subtitles, video, and audio parameters.
Then choose the temporary directory to save the resulting video. As can be seen from the picture, DVDFab Blu-ray Ripper makes it available to save video directly to your iPhone 11, store it as a movie folder or share it onto Facebook, YouTube or Instagram without a hitch.
What’s more, DVDFab Blu-ray Ripper allows for editing the resulting video with its in-built video editor in the aspects of watermarks, subtitles, background art, cropping, trimming and merging clips.
Note that if you want to gain a resulting video smaller than that of the source size, you can downsize it via making modifications to its file size. Besides, you can tick ‘Disable all GPU codecs for decoding and encoding’ or choose ‘Enable Lightning-recoding when applicable’ if there is a need for you to speed up the converting process. Mind that you need to check whether your graphic card is compatible with the acceleration feature. By the way, if you mean to upscale video from 1080p to 4k, you can activate Enlarger AI, the world's best AI video upscaling software for you to enhance video quality substantially.
Step 3: Start to rip Blu-ray to iPhone
Once you tab ‘Start’ icon to convert Blu-ray to iPhone, an interface showing detailed ripping progress information will pop up in front of you. In the meantime, a triangle icon embedded in the progress bar is designed to preview the video during the ripping process.
Here, DVDFab Blu-ray Ripper has a striking feature that makes it possible for users to achieve batch conversion through multi-threading (meaning that users can run several DVDFab 11 to rip Blu-rays to iPhone at the same time) and navvy-tech acceleration.
Once done, a reminder telling you ‘Process Complete Successfully’ comes up. After you gain an MP4 video, you probably cannot wait to open and watch the video. Considering your actual demand, DVDFab Blu-ray Ripper invites you to watch the video on PC/Mac directly through an inserted shortcut icon that navigates you to DVDFab Player 6, the world’s first and powerful player software designed to play DVD/Blu-ray/4k UHD, not to mention its function of playing MP4 video.
Without doubt, another simple and fast way is to play video on your iPhone (11/Pro/Pro Max). Here, iTunes might be the optimal choice for you to manage and play your loved videos.
Part Four: How to Convert and Rip Blu-ray to iTunes
As we know, iTunes is a source of listening to music, watching movies, and television shows. However, it supports any video format that works with Quick Time and video files bought or rented from the iTunes store. Besides, up to now, MP4, MOV, M4V are proved to be supported by iTunes. Considering this, this part aims to teach you how to convert and rip Blu-ray to iTunes. According to Part Three, when you get an MP4 video, you need to add it to the iTunes library. The following tips may be helpful to you.
First, launch iTunes on Win PC or Mac.
Then, drag video files from desktop to iTunes window or drag it from the Finder (for Mac) there.
Once done, the MP4 video will be imported to the Movie section of the iTunes library. In this way, you have finished converting and ripping Blu-ray to iTunes.
Here one thing worth mentioning is that you can choose the output format of MOV and M4V before starting to rip Blu-ray to iPhone in Step 2 of Part Three. Then try to add the resulting video to iTunes, too.
This article has guided you to a one-stop solution to rip Blu-ray to iPhone and further play the video on PC/Mac, or even on iTunes. Perhaps, you have gained a nice user experience via shoot-trouble the way to convert Blu-ray to iPhone (11/Pro/Pro Max).
As a matter of fact, DVDFab has always kept with the time and even stands out among others to provide users with the timely, optimal, and cost-efficient solutions concerning DVD/Blu-ray/4K UHD. Apart from DVDFab Blu-ray Ripper, you have easy access to trying relevant products that suit your needs.
1. Convert Blu-rays to AAC, MP3, MP4, MKV, M2TS, and etc.
2. Support all the popular smartphones, tablets, PDAs, and etc.
3. Freely customize the output audio & video parameters
You May Need Other Tools
DVDFab Player 6 Ultra
World’s best media player able to play DVDs/Blu-rays/4k Blu-rays/HEVC and regular videos
DVDFab Passkey for Blu-ray
Enable users to freely access and watch any Blu-ray and 4K Ultra HD Blu-ray movie (Cinavia protected media excluded) without limit
DVDFab Enlarger AI
World's best AI-powered video enhancer able to upscale video from 360p to 1080p, or from 1080p to 4k
