[Best Solution] Burn M4V to DVD without a DRM Removing Software
2020-10-27 05:01:30     Posted by Emily
1697
Summary: I bet you must have read articles telling you that you have to remove DRM protection first if you want to burn M4V to DVD. Well, this is not the best choice for you to burn M4V to DVD because with the DVDFab DVD Creator software you are able to converting M4V to DVD directly. Go on reading to learn this best solution.
There is no question that we are likely to enjoy movies and TV shows in a large screen. So if you have a bunch of collections of M4V files on your iTunes, it is normal to wonder how to burn those M4V files to DVD so that they can be played on a home screen. Before exploring the method of burning M4V to DVD, let’s get to know the M4V format first.
What is M4V?
M4V  is a MPEG-4 file extension used for TV episodes, movies, and music videos in iTunes Store. And M4V files can only be available on Apple portable devices, such as iPod, iPhone, and iPad, etc. That’s because most of the M4V files are under DRM protection. So sometimes you may find it hard to convert M4V to DVD even though these files is complete and unbroken. However, this is not a problem for the DVDFab DVD Creator program when you want to burn M4V to DVD disc with ease.
Part 1: The DVDFab DVD Creator - Burn M4V to DVD
DVDFab DVD Creator is a full-featured DVD burning software that allows you to burn all sorts of videos into DVD disc or to be standard DVD ISO files/folders. Out of users’ concern, this best DVD creator is completely safe and clean and offers a 30-day trial to let you know this software better before buying.
1-1: Basic Information of it
• Major features of it:
Create a DVD menu
Customize the DVD menu with built-in templates
Clean and navigable interface for understanding
Preview video to check the content
Simple to use for both experienced and non-experienced users
Fast M4V to DVD conversion speed
Provide multiple languages
• Working platform:
Win and Mac
• Supported input formats:
MKV, MP4, AVI, M2TS, TS, MOV, WMV, WMA, 3GP, FLV, M4V, VOB, etc.
• Supported output formats:
DVD-9, DVD-5, DVD+R/RW, DVD-R/RW, DVD+R DL, DVD-R DL
1-2: How to burn M4V to DVD with the DVDFab DVD Creator?
Speaking of how to burn M4V to DVD with this best DVD creator program, only a few steps are involved and we have listed the steps in detail.
Step 1: Download and install this best DVD burner
Click on one of the downloading button to download this best DVD burning software on your computer and also install it by following its instructions.
                                              i  Free Download                         i Free Download
Then, double-click its desktop icon to start it.
Note: Before M4V to DVD conversion, you can change the color of the interface skin via that small cloth icon on the right upper-side corner. And you can click on that inverted button to set common setting, such as language, switch the interface to mini, or authorize to this DVD burning program if you have bought it.
Step 2: Add your M4V file
Make sure you enter to the Creator module and have find the DVD Creator mode. Then, you can drag & drop your M4V files to the interface in order to make M4V to DVD.
Step 3: Burn M4V to DVD
It is time to personalize your video and burn M4V to DVD. As we have mentioned early, you can create a DVD menu. To do that, please click on the Set Menu. As a result, a new interface pops up from where you can select many built-in templates, or add some images, even texts to your DVD menu.
Apart from this, you can click on that Advanced Settings to opt for an output volume, DVD-9 or DVD-5, or select a quality.
Step 4: Start the M4V to DVD process
The last steps goes to click on that Start button. However, make sure you have choose an output directory for your DVD file before the conversion.
Once you click on the Start button, the M4V to DVD process shall begin and will finish in a fast speed.
To conclude, the DVDFab DVD Creator is the best M4V to DVD burner that let you create DVD from M4V file without downloading another DRM removal tool. If you have to remove DRM from M4V files, then you can try the DVDFab DRM Removal for Apple tool to help you with it.
Part 2: The Alternatives of DVDFab DVD Creator
2-1: Online UniConverter - For the Professional Person
Online UniConverter is an online-based tool that allows you to convert M4V to DVD online without downloading a third-party program on your computer. It is an all-in-one media converter tool with the ability to convert video, audio or images to many other formats. If you are a professional video editor and needs to convert videos very often and in many ways, you can try it.
Shortcomings:
The only thing should be noted is that this tool may consume you more time to finish the M4V to DVD process. Besides, it doesn’t offer any free trial for you, so you have to spend $39.9 per year before knowing it well.
2-2: WinX DVD Author - For the Beginners
If you have no many demands in the process of burning M4V to DVD, then I bet the WinX DVD Author can also be your list. This is also a free, clean and professional M4V to DVD burner which allows you to add DVD background music and background pictures.
Shortcomings:
The biggest downside of this burner is that it doesn’t support all MP4 files and it is very hard to launch.
2-3: BurnAware Free - A M4V to DVD Freeware
BurnAware Free is makes everything accessible and easy. It supports CDs, DVD, Blu-rays and dual-layer media, and you can create data, music, video, and bootable discs, as well as working with images. However, as a M4V to DVD freeware, it does have limitations, for example, if you want a disc-to-disc copying, you may need to upgrade it to its premium version. So, if you don’t care about its limitations and just burn M4V to DVD occasionally, the BurnAware Free version is what you need.
Shortcomings:
Only available on Windows 10 system;
Empty looking interface;
No disc-to-disc copying;
No context menu integration
In the End
Up to now, we have talked about the best solution to burn M4V to DVD - the DVDFab DVD Creator, and also its alternatives - Online UniConverter, WinX DVD Author and BurnAware Free. And they all have their pros and cons. So it’s all up to your needs to decide which one to choose.
The best DVD ripping software that can quickly rip and convert a DVD to any mainstream audio & video formats for playback on PCs, portable and mobile devices.
You May Need Other Tools
DVDFab DVD to Blu-ray Converter
Convert DVD to Blu-ray for high quality
DVDFab DVD Copy
Backup your DVD movies with this professional software
DVDFab Blu-ray Creator
Create Blu-ray discs without effort
