Rip Audio from DVD with 3 DVD Audio Extractors 2021
2021-01-27 06:45:57     Posted by Starry
25447
Summary: This post aims to present you three DVD audio extractors used to rip audio from DVD and demonstrate how to rip audio from DVD with the best DVD ripping software, DVDFab DVD Ripper.
If you're still around with a box full of physical DVD discs while all your neighbors have already got them converted to digital formats and even have them saved on personal account of cloud storage service platforms for lasting preservation, chances are that there is still time before its afternoon. After all, better late never than never. Above all, ripping audio from DVD for playback on portable devices whenever and wherever possible can inject new life to the hustle and bustle of your life. This post has everything you need to extract audio from DVD, thus enhancing your audio experience.
Quick Navigation
1. Top 3 DVD Audio Extractors to Rip Audio from DVD
When it comes to ripping audio from DVD, you absolutely need professional tool called DVD Ripper or DVD audio extractor that works in minutes to extract audio from DVD, converting them to one of the mainstream audio formats that can be played on mobile device or saved on HDD or onto cloud storage services. If you anticipate extracting audio from DVD, below DVD audio extractors, either desktop or online, will be your top priority.
DVDFab DVD Ripper (Best Solution to Rip Audio from DVD )
Available: Windows and Mac
Supported Tech: latest GPU hardware acceleration featured by Intel Quick Sync, NVIDIA CUDA and Multi core CPU working together to quicken the ripping and conversion process
Highlighted Features:
  • Rips audios/videos from DVD of various formats playable on player software and portable devices
  • Advanced Settings and built-in video editor applied to customizing output content
  • Fast and batch conversion achieved by GPU hardware acceleration and multi-core CPU
  • Works seamlessly with Enlarger AI to upscale video resolution from 480p to 1080p, even from 1080p to 4k
  • Intuitive interface suitable for beginners and professionals
  • Share converted audio on YouTube, Facebook and Vimeo
  • 30-day free trial
Output Video Formats:
3D Videos: 3D MKV.H.265, 3D MP4.H.265 3D MP4.4K, 3D MKV.4K, 3D AVI, 3D MP4, 3D WMV, 3D MKV, 3D M2TS, 3DTS
2D Videos: H.265, MP4.4K, MKV.4K, MPEG-4, MP4 Passthrough, MKV Passthrough, MP4, FLV, MKV, AVI, WMV, M2TS, TS, etc.
Audio: MP3, MP4, M4A, WMA/WMA10, WAV, AAC, DTS, OGG, PCM and AC-3/E-AC-3 5.1 etc., with up to 7.1 channels
Seen from above, this DVD Ripper and DVD Audio Extractor stands out from the crowd due to its powerful and full features. With this DVD ripping software, you can rip audio from DVD with blazing fast speed and stunning quality.
Handbrake  (Open-source DVD Audio Extractor)
This open-source DVD Ripper, available on Windows, Mac and Linux, acts as an audio extractor to rip audio from DVD into MP3 encoding without spending a single penny. However, this DVD ripping program does not support audio-only conversion. If you intend to convert audio from one format into another, you can resort to other alternatives like DVDFab Video Converter. Note that ripping DVD into MP3 will cause some quality loss. Besides, this DVD ripper software is well-known as a video transcoder to compress video into smaller files for web storage and sharing.
ZAMZAR (Online DVD Audio Converter)
This online DVD audio converter allows you to DVD or VOB files and extract audio from DVD to music formats like MP3, AAC, M4A etc. for better playback on your mobile devices. This is a cloud-ready platform, hence, converted audio files are directly stored in the cloud. You have to upload and download them once the actual conversion is over. Nevertheless, this DVD audio extractor fails to rip audio from DVD if the source DVD or VOB file is corrupt, password-protected or restricted by DRM (Digital Rights Management). Meanwhile, free version of audio extractor has limited features. For example, converted file shall not exceed 150 MB.
These are three recommended DVD audio extractor to rip audio from DVD in different usage scenarios. What to choose depends on your personal use and actual need.
2. How to Rip Audio from DVD with DVDFab DVD Ripper
Now you might anticipate figuring out how to rip audio from DVD with the best DVD Ripper. The following guideline will give you a better clue.
Step 1: Run this best DVD Ripper and load source DVD
Download and install this free DVD Ripper (integrated into DVDFab11), and opt for ‘Ripper’ module when the program runs. Then insert DVD disc into the optical drive on PC or navigate ISO file or DVD folder from HDD through ‘+Add’ button, or simply drag & drop it onto the main UI. This best free DVD ripper allows you to rip audio from DVD for 30-day free trial.
Step 2: select one profile and customize output audio
Select your desired profile from the profile library. You can rip audio (like MP3) from DVD.
Then tab ‘Wrench’ icon (for Advanced Settings) to set audio parameters such as codec, sample rate, channels, bit rate and volume. Besides, you can choose to split chapters to rip audio from DVD.
Step 3: Start to rip audio from DVD
Set file directory to save the output audio on HDD or mobile, even share the converted audio onto social network such as YouTube, Facebook and Vimeo. More importantly, ‘GPU Hardware Acceleration’ will speed up the whole conversion. Once done, tab ‘Start’ button to wait for the ripping process and check the real-time progress. You can cancel the task of extracting audio from DVD anytime as you want to, set PC to automatically shut down, exit program, hibernate or do nothing when the task is done.
The above-mentioned steps are how to rip audio from DVD fast and well. In a nutshell, this best DVD Ripper has the ability to rip audio from DVD that can be playable on all devices such as smartphones, tablets, game consoles, 3D devices and TV boxes. You can playback the converted audio whenever and wherever possible.
Now you have understood what to choose from an ocean of DVD Ripper programs to rip audio from DVD with fast speed and nice quality. Anyway, if you are unhappy with the quality of converted audio, you can edit audio with professional audio editing tool.
1. Convert DVDs to AAC, MP3, MP4, MKV, AVI, and etc.
2. Support all the popular smartphones, tablets, and etc.
3. Freely customize the output audio & video parameters.
You May Need Other Tools
DVDFab Toolkit
A versatile and professional multi-media toolkit able to edit video, audio and image
Best video converter to able convert videos/audios between various formats and edit/compress videos as needed
DVDFab Enlarger AI
Best AI-powered video upscaler able to upscale video from 480P to 1080P, even 4K
