How to Convert 1080p to 720p Easily for Special Use?
2021-03-23 06:24:34     Posted by Starry
38941
Summary: If you have lots of footage at hand, why not convert 1080p to 720p for less storage space on HDD or for smooth upload on video sharing sites? This post aims to details how to convert video to 720p free and easily for special use. Read on to choose your favorite solution.
Can I convert 1080p to 720p? How do I change video quality to 720p? Most people might feel surprised because convert video to 720p will affect image quality. However, there are still some occasions when you have to convert 1080p to 720p. For instance, some video sharing sites require video upload in 720p for the sake of storage capacity of their server. In some cases, you might need to convert video to 720p for better play on your HD compatible devices.
Is it easy to convert video resolution? Yes. How do I convert 1080p to HD? There are some 1080p to 720p converters for your option. You are lucky to read this post since it details how to downscale 1080p to 720p free and easily.
{{DIRECTORY}}
1. How 1080p and 720p Are Similar and Different?
Before converting video resolution from 1080p to 720p, tell apart such two video resolution concepts. 1080p and 720p both are versions of HD, and they also share in common that they display video in the way of progressive scanning (that is what the p letter stands for), which means that each line of pixels is displayed following another. However, they are different in other ways.
1080p, also known as full HD or FHD, is a set of HDTV high-definition video modes characterized by 1920 pixels displayed horizontally and 1080 pixels displayed vertically, yielding 1080 horizontal lines. So the 1080p we always say refers to the vertical resolution. 1080p is often used in Blu-ray discs, smartphones, some internet contents, HD camcorders, video game consoles, etc. If you want to convert 720p to 1080p converter, have a free trial of Video Enhancer AI, an AI-based professional video enhancer that can improve video quality to 4K automatically without watermarks. Likewise, it can convert video to 720p as well.
 i  Free Download
720p is a progressive HDTV signal format characterized by a resolution of 1280 x 720, with 1280 pixels displayed horizontally and 720 pixels displayed vertically. There are 720 horizontal lines of pixels in a 720p video. Some devices fail to play 1080 movies smoothly. Then it is time to convert 1080p to 720p if you don't want to change a video player.
The main difference between 1080p and 720p is the pixel number that makes up 1080p and 720p images. 1080p contains about 2 million pixels while 720p only has about 1 million pixels. Therefore 1080p can display more details and provide much clearer video than 720p. You can improve 720p to 1080p with DVDFab Video Enhancer AI.
2. DVDFab Video Converter
To convert 1080p video to 720p, you can try another best Video Converter. DVDFab Video Converter is a full-featured yet easy-to-use video converter that can convert 1080p video in any popular format to 720p video in any mainstream format with the high video quality. With the employment of hardware acceleration technology, this video converter 1080p can convert a video at a pretty fast speed. Moreover, this 1080p MP4 converter allows you to customize your video freely by editing the video with the built-in video editor and setting the parameters on the advanced settings panel.
In addition, to convert 1080p video, DVDFab Video Converter also can convert 4K video (video with a resolution of 4096 x 2160) to various formats or convert videos in various formats to 4K easily and quickly. So if you need a 4K converter, you can also choose this MP4 converter 1080p.
This is a converter that can read all the popular video formats from the Internet, digital camcorders, capture cards, etc. and convert them to any mainstream video/audio formats.
3. How to Convert 1080p to 720p Free & Easily
Now let me show you how to downscale 1080p to 720p with DVDFab Video Converter. How to convert 1080p to 720p free and easily? Follow the steps below and you will make it.
Step 1: Run DVDFab Video Converter and load video source
Run DVDFab 12, go to Converter module and load the 1080p video source.
 i  Free Download     i  Free Download
Step 2: Choose a profile
Go to the profile library on the top left corner of the interface and choose a format you want to convert to. This 1080p to 720p converter supports many video formats you want.
Step 3: Customize the video
Then you can customize the video according to your needs using the options offered in this 180p MP4 converter. You can change the video name and choose the audio track and subtitle you want, you can edit the video with the built-in editor and you can set the video and audio parameters on the Advanced Settings panel. How to convert 1080p to 720p? On the Advanced Settings panel, you can change the resolution to 1280 x 720.
On the Advanced Settings, there are lots of parameters related to video, audio and subtitles. Click them and explore how to change 1080p to 720p and edit your file.
Another tool deserving your attention is this MP4 converter is the Video Edit button. Click it and you will be able to add text, credit, music, image, trim, crop, speed up and down, zoom in and out, and set the video properties of your video. So this 1080p MP4 converter is more than a program to show you how to convert 1080p to 720p.
Navigate to the bottom of the main interface and click the folder icon to select a directory to save the output video. There are three choices in this video converter 1080p. Choose one you want and save your file after learning how to convert video resolution with DVDFab Video Converter.
Step 5: Start the conversion process
Click the Start button at the lower right corner to start the process of converting video. Then you will change 1080p to 720p quickly with this MP4 converter.
After only a few minutes, you can get a 720p video. It’s really easy and convenient to convert 1080p video to 720p with DVDFab Video Converter, right? Just download DVDFab Video Converter and have a 30-day free trial!
One more word, if you want a more professional video editor that boasts ample creative effects and ablity to change video quality, you shall never miss out on VideoCruise. It is a versatile video editor that enables you to create masterpieces via professional editing features and ctreative special effects. Besides, it can convert video to 1080p or convert video to 720p as desired. Click here to master how to use VideoCruise.
In this post, we have discussed different ways to convert 1080p to 720p for diverse situations. It does not bother to keep a 1080p to 720p converter at hand in case you will need it some other day. Please bear in mind, converting video to 1080p or 720p will facilitate your playback or upload on social networks. Just choose your desired 1080p to 720p converter as per your personal preference.
Hot topics recommended:
Disney Plus: Download Disney Movies and Songs for Free
Gfycat Download with Sound on PC and Mobile [Offline & Online]
How to Download Netflix Movies on Laptop
Download Amazon Prime Video to Any Device [PC, iPad, iPhone, Android, Disc]
WeSing: Download Best Karaoke Songs Free
Unblur Photos Free and Fast [Remove Blur From Photo]
Anime Movies Free Watching and Download 2021
DVD Movies Download [Movie from DVD; YouTube Movie Download; Burn Movie to DVD]
Watch Harry Potter on PC/Smartphone/TV [YouTube Download]
1. Download videos from 1000+ audio & video sharing websites
2. Choose user-specified video quality for the download, up to 8K
3. Support playlist download or process 5 downloads concurrently
4. Offer turbo-speed download more that's 10X faster than normal
You May Need Other Tools
StreamFab All-In-One
Download from Netflix, HBO, CBS, etc.
DVDFab Player 6 Ultra
Play DVDs, (4K UHD) Blu-rays, 3D, HEVC, 4K videos & other media files
Upscale low-res video to 4K & enhance old video quality
