Anaglyph 3D, SBS 3D and Top/Bottom 3D
2020-12-26 03:11:56
DVDFab has a super powerful 3D converter software bundle which includes DVD Ripper, Blu-ray Ripper, Video Converter and 2D to 3D Converter. With those tools working together, you can turn regular DVDs, Blu-rays and videos into 3D videos in a couple of formats, like side-by-side 3D, anaglyph 3D, two separate files, and even two video streams in one file. The converted 3D videos play quite smoothly 3D armed computers, 3D TVs, glasses-free 3D smartphones, or other compatible 3D devices.
Here this tip is to teach you how to convert your regular DVDs, Blu-rays and videos into 3D videos.
Turn 2D Videos into 3D Videos> Step 1: Download and install the latest DVDFab 12 onto your computer;
Turn 2D Videos into 3D Videos > Step 2: Launch DVDFab 12, choose Ripper option from the Option Bar at the Main Interface, then load the to-be-converted 2D DVDs from your disc drive;
Sidenote: Partnered with 2D to 3D Converter, Ripper tools will convert 2D DVDs and Blu-rays into 3D videos; To convert 2D videos into 3D videos, you need to select Converter tool at this step.
Turn 2D Videos into 3D Videos > Step 3: Click the Profile Selection Box which takes you to DVDFab Built-in Profile Library, check the 3D filter at the Video column, and then select the profile you want, for example, 3D.MP4;
Turn 2D Videos into 3D Videos > Step 4: Click the wrench icon to open the Advanced Settings panel, where you can change relavent settings regarding video, audio, subtitle and 3D Format;
Sidenote: click 3D tab, you can choose one 3D format from the available options, side-by-side 3D, anaglyph 3D, two separate files, and even two video streams in one file.
Turn 2D Videos into 3D Videos > Step 5: Click the small pencil icon behind the wrench to open the Video Edit panel where you can customize the resulting 3D video. After you have done here, return to the main interface to “Start” the conversion process.
Software you need: The latest build of DVDFab 12
Product you need to order: DVD Ripper, Blu-ray Ripper, or Video Converter and 2D to 3D Converter
For more info, please go to: www.dvdfab.cn/2d-to-3d-converter.htm
