Blu ray to MKV/M4P/M2S/TS and More with DVDFab Blu-ray Ripper
2020-12-26 03:11:42
Blu ray to MKV instruction. Over the past several years Blu-ray has become one of the most popular formats, especially when it comes to movies. It’s no secret that Blu-ray videos look and sound better than many other formats but that excellent quality tends to come at a price. A Blu-ray video is generally quite larger than the same video in a more common format like MKV, MP4, AVI, FLV and more. That's why people want to rip Bluray to MKV.
While file size is less of an issue these days, there are still a lot of people that don’t have huge hard drives. Not to mention the people who want to watch their favorite videos on phones with rather limited storage capacity. So Blu ray to MKV is necesary. Luckily, you can circumvent those issues by using a Blu-ray (video) converter like the one offered by DVDFab. With the assistance of this Bluray to MKV converter - DVDFab Blu-ray Ripper, you can convert Bluray to MKV or any other formats like MP4, M2TS, TS, and more.
1. Features DVDFab Blu-ray Ripper
No matter which Bluray to MKV converter you choose to rip Bluray to MKV, pay attention to its main features.
Main Features:
• Support many output video formats, including MKV, MP4, M2TS, TS, etc.
• Provide a powerful video editor, helping you customize your video
• Convert Bluray to MKV in batches without losing any quality
• Rip Blu ray to MKV 10x times faster supported by hardware acceleration
• Offer files merging and multi-threading services
• Free trial within 30 days
2. Convert Bluray to MKV with DVDFab Blu-ray Ripper
Now, I'm going to show you how to rip Blu ray to MKV with this free software. You can download and install this Bluray to MKV converter on Windows or Mac in advance. It's very easy and just needs three clicks.
   i  Free Download       i  Free Download
Step 1: Choose the "Ripper" Module
DVDFab Blu-ray ripper is part of the DVDFab 11 software suite. So in order to rip Blu ray to MKV, you need to click the "Ripper" module located in the upper menu after launching this free software.
Step 2: Load the Source
With the Ripper module selected, it’s time to load the Blu-ray you wish to convert. Which kind of Bluray to MKV? If the source is a Blu-ray disc, you can insert the disc to your optical drive and DVDFab will load it automatically.  If the source is a Blu-ray folder or ISO file, you can simply click the big “+” button found in the middle of the UI and navigate to the source. Or you can also drag and drop the folder or ISO to the main interface to load it.
Step 3: Choosing a Profile
Change to your desired format by clicking on the "Profile Switcher" highlighted in the red square at the top left of this Bluray to MKV converter. This can be done by clicking the little button found in the upper left corner of the UI. Here, under the option of "Format", you can go to the "Video" category and choose one of the many available formats at your disposal. If you want to get a bit more specific, you can use the various filters to only show 4K or 12bit formats, for example. "Convert Bluray to MKV" with this DVDFab Blu-raay Ripper is very easy.
Also Format, selection, you can also click the "Web Optimized" section. if you would rather convert Blu rays to MKV for uploading to YouTube. Meanwhile, going to the "Device" tab will let you convert  Bluray to MKV playable on smartphones, tablets, gaming consoles or other compatible devices. If you want to use this option, simply click on your device’s brand and then model.
In the Bluray to MKV conversion, it’s worth noting that using the Web Optimized or Device options results in MP4 profiles a lot of the time. Use Format if you want more control over the output. In this example we’re going to use the Blu-ray converter to turn our video to M2TS for demonstration purposes but feel free to use any format that works best for you.
Step 4: Advanced Settings
Customizing videos in DVDFab 11 is quite simple and can be done via the "Advanced Settings" menu. In order to access this menu, click the little wrench icon and then pick between the various dropdown menus to begin making adjustments. This is a very helpful video editor when you convert Bluray to MKV.
For example, in the first section of the menu below you can change the video resolution, bit rate, frame rate, codec, encoding method or split it. If you’re already familiar with video customization you can make use of the Bits/Pixel slider to achieve the desired quality to size ratio. Alternatively, you can also manually add specific values in the fields marked “Bit Rate” and “Output Size” during the Bluray to MKV conversion. But if you don’t want to mess around with too many settings here you can just speed up the process by selecting a Video Quality preset.
The audio settings work in a similar way, with the menu allowing you to choose the sample rate, bit rate, codec or channels of the video. Of course, there’s a volume slider as well in this Bluray to MKV converter. The last section of the menu is dedicated to subtitles and there are three options to choose from – Direct render to video, Remux into file, and Extract to idx/sub file. So add or extract subtitles from MKV is very easy when you convert Bluray to MKV using this free software. Choosing the first option will result in hardcoded subs that cannot be turned on or off. The other two options output subs that can be turned on or off, with the last option also extracting them into a separate idx/sub file instead of embedding them directly into the video.
Besides Bluray to MKV conversion,  these settings also allows you to convert 2D videos to SBS 3D. If you used the 3D filter earlier when picking the format, you’ll see an additional section in the "Advanced Settings" menu known simply as 3D. Simply pick one of the options from the dropdown menu to get started and then adjust the gain and visual depth of the output by using the two sliders.
Druing the Bluray to MKV conversion, you can also quickly change the name of the video, select the audio tracks and subtitles you want to be added to the output, as well as the chapters and titles you want to rip. Moreover, there’s also a handy dropdown menu that lets you quickly choose a quality present without having to access the Advanced Settings menu anymore in this Blluray to MKV Converter.
Step 5: Video Editing
If you want to edit MKV during Bluray to MKV covnersion, there is another option available - "Video Edit". Here, let me show you how to add text, image, add subtitles with this Bluray to MKV converter. And how to change video properties, trim/crop videos, etc. based on your needs.
Watermarks and Subtitles
On the main interface of this Bluray to MKV converter, click the option ot "Video Edit" and you will see the image above. Here, pay attention to the left and you will see three options of "Text". Use it to add words to your video and you can also customize your text in this free software.
After clicking "Text" in this Bluray to MKV converter, scroll down and you will see "SUB" option. Finally, Use  this option to upload subtitles and change the font, size, and color of the subtitles or make them bold or italic. You can also add a delay, modify their position, select the language, and more.
Then it is easy to know how to add image to video when you rip Blu ray to MKV, just use the option of "Image" on the left.
Video Properties, Cropping, and Trimming
How to use such video editing tools when you rip Bluray to MKV? The first icon on this row allows you to change video properties such as Brightness, Contrast, and Saturation with the help of the three sliders. Here, you can also rotate videos clockwise or counterclockwise by increments of 90 degrees.
The second icon in this Bluray to MKV converter gives you access to the cropping tool. Here, you can use the dropdown menu to quickly crop the video according to a specific aspect ratio, such as 4:3 or 16:9 for example. If you want more control over the cropping process, you can instead manually add your desired values in the four fields located to the right of that Crop Aspect Ratio menu.
Finally, the Bluray to MKV converter also includes a trimming tool, which can be accessed by clicking the icon to the right of the Cropping tool. Here, you can use the two little red arrows to adjust the start and end time of the section you want to trim. Or, use the fields underneath the progress bar if you would prefer to instead add the start and end time manually.
Step 6: Choosing the Output Destination
There are three output destination provided by this Bluray to MKV converter. First, you can use the bottom left menu to quickly choose a local folder or the mobile device you want to send the converted video to. It’s worth mentioning that only MP4 supported formats can be transferred directly to mobile so we can’t use the option in this case.
If your preferred destination can’t be found in the menu list, you can add a different one by clicking the little folder icon. You can also use the adjacent globe icon to upload your converted video directly to YouTube after converting Bluray to MKV. Keep in mind, though, that you’ll first need to sign in to your YouTube account before you can use this option.
Step 7: Starting the Conversion Process
Now that everything else has been taken care of we can go ahead and fire up the Bluray to MKV video converter. To do this, simply click the Start button found in the lower right corner of the UI or the little arrow next to it if you want to schedule the process for later. Clicking the ‘Start Later’ button will initate this popup.
To change the time, head over to your ‘Task Queue’ and look at the bottom of this Bluray to MKV converter. There, you will see an option ‘Start the task(s) at.’ Here, you can change the time.
Final Thoughts
We hope this guide has helped you learn more about how to convert Bluray to MKV/M4P/M2S/TS or any other format with DVDFab 11’s Blu-ray Ripper. As the software is pretty straight forward, after playing around with it once or twice, you’ll get the hang of it. While this post covered Blu-ray video conversion, we’ve also outlined how to extract Blu-ray audio on Windows and Mac.
