How to Rip and Convert DVD to PS3 with DVD to PS3 Ripper?
2020-12-26 03:11:42
We all know that PS3 can playback DVD, but there are the occasions that you may don't want to play a DVD on PS3 because you value the DVD very much and try to avoid playing it so often, or that you may think it is inconvenient for you to carry a DVD all the time to make it possible to play it on PS3 at any time. For the above situations, you badly need a DVD to PS3 Ripper to convert DVD to the video format supported by PS3 so that you can store the video on your hard disc and play it often. Then what you need is DVDFab DVD Ripper. DVDFab DVD Ripper converts DVD file and optimizes it for playback on PS3, so choose DVDFab DVD Ripper when you need to convert DVD to PS3!
How to Rip and Convert DVD to PS3: Step 1> Run DVDFab 12 and choose the Ripper module.
How to Rip and Convert DVD to PS3: Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to PS3: Step 3> Navigate to the profile library via the "choose other profile" option from the Profile Selection Box, and choose Device >Sony >Play Station 3.
How to Rip and Convert DVD to PS3: Step 4> Now you can choose the titles, chapters, audio tracks, and subtitles, define the names of the titles by clicking corresponding tabs according to your needs.
How to Rip and Convert DVD to PS3: Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
For more detailed information about DVDFab DVD Ripper, please visit https://www.dvdfab.cn/dvd-ripper.htm
