How to Copy DVD with DVD Copy for Mac?
2020-12-26 03:11:56
Got a movie DVD and wanna save it on your Mac computer? That is pretty much an easy job for many of us. There are a lot of programs that offer different solutions; however, you just need to find one that fits your situation best. Backing up DVD movies on Mac with DVDFab DVD Copy for Mac is as easy as drinking a cup of tea, as it is the best Mac DVD copy software ever.
Find out how easy it is by going over this tip:
Copy DVD with DVDFab DVD Copy for Mac: Step 1 >After downloading and installing DVDFab 11 for Mac, start it and navigate to Copy option, and then load the DVD you want to rip;
Copy DVD with DVDFab DVD Copy for Mac: Step 2 > Select one copy mode from Mode Switcher, like Full Disc, or Main Movie, or Clone, choose an output size on the Left Pane of DVDFab main interface;
Copy DVD with DVDFab DVD Copy for Mac: Step 3 > Select a directory from you Mac HDD to save the result at the “Save to” section, and then press the Start button to go ripping.
Note:  You can even select to choose a certain chapter range of the movie title, some certain audio tracks and subtitle streams to copy if you choose the Main Movie mode;
Software you need: the latest build of DVDFab 11
Product you need order: DVD Copy for Mac
 For further information, please visit www.dvdfab.cn/dvd-copy-for-mac.htm.
