Top 10 Best Blu-ray Burning Software 2021
2021-09-29 06:12:19     Posted by WiKi
46176
Summary: Bluray burner review. This article aims to give you a picture of top 10 best Blu ray Burners that can burn Blu-rays easily and quickly for home playback. Though there is numerous paid and free Blu-ray burning software on the market, it’s still worthwhile to take the best pick based on the close comparison.
Increase people choose to burn Blu ray discs instead of DVDs, which drives the need for Blu ray burning software? Do you know the reason for that? Here, in this article, I will compare Blu-ray burn and DVD burn, and show you the best free Blu ray burning software Mac and Windows 10/8.1/8/7. Then, you will be able to burn Avatar movie to a disc or other movies you like?
{{DIRECTORY}}
1. Blu-ray burning vs DVD burning
Which one do you prefer, Blu-ray burning software or DVD burner to back up Avatar or other famous movies? Compared with DVD burning, what is the advantage of Blu-ray burning? Let’s start with the video quality. As a matter of fact, Blu-ray video quality is better than any streaming service. Blu-ray movies are 1080p, full of sharp images and clear details, usually present with a sound aspect ratio; while DVD movies are only 480p, lower in resolution than most YouTube videos, usually displayed on a stretched 4x3 fullscreen. With the help of Blu ray burning software, you can get a video in high definition. Anyone with a surround sound system at home will burn videos to Blu-ray instead of DVD, in order to get uncompressed 4K video and audio, together with multichannel. Thus, Blu ray burning service is still very popular. Now, follow me to pick out the best Blu-ray burner for your use.
Do you know any best free Blu-ray burning software on the market? Though cloud storage and USB stick are prevalent these days, disc, especially Blu-ray disc, is still an excellent way for storing and sharing large data and high definition video or movie. There are so many free Blu-ray burning software programs in the market for you to back up and create Blu-rays, so you may feel dizzy if you have to pick out the best Blu-ray burner software to use. Don’t worry, we have tested and found the top 8 best Blu-ray burning software used to burn Blu-ray easily and quickly on Windows and Mac. Now let’s take a look at these best Blu-ray burners and make it clear why Blu-ray burning is so popular.
2. Top 10 Blu ray burning software
There are 10 Blu ray burners introduced, including internal Blu ray burning software and external Blu ray burners.
(1) DVDFab Blu-ray Creator
  • Blu ray burning software Mac 10.10 - 11.3
  • Blu ray burner Windows 10/8.1/8/7
  • Burn VOB/MKV/MP4/3GP/AVI/FLV/M2TS/WMV/MOV/MPEG/OGM/RMVB/TS/WEBM to Blu-ray disc/folder/ISO file
  • Convert Video to BD 25 or BD 50
  • Able to read download YouTube videos and camcorder-recorded files
  • Burn videos to Blu-ray in 1:1 ratio without quality loss
  • Create Bluray ISO/disc/folder in batches
  • Work 30x faster than other Bluray burners
  • Allow you to create Blu ray menu flexibly and offer built-in manu templates
  • Free -to-use for up to 30 days
DVDFab Blu-ray Creator is free Blu-ray burning software that is used for burning various videos to blank Blu-ray disc/folder/ISO file, including BD 25 and BD 50. No matter your videos are downloaded from YouTube, or recorded with a camcorder, this blu-ray burner software is able to read the source. DVDFab Blu-ray Creator is a flexible Blu-ray burner that allows you to burn and merge more than one video into one Blu-ray disc and gives you the right to arrange the playback order. So how many movies are you going to process with this best free Blu-ray burning software? Just start for batch Blu-ray making. With 30-day free trial, you can use this Blu-ray creator at will and customize your own Blu-ray playback menu with the built-in menu templates. For example, you are able to set the frame, font, layout, etc. in the menu template. Now, let's see how to use the best blue ray burner.
 i  Free Download    i  Free Download
Steps 1: Download and install DVDFab Blu-ray Creator
Would you recommend a Blu ray burner/reader that works with Windows 8.1? DVDFab Blu-ray Creator is such a Blu-ray burner. It works on Windows 10/8.1/8/7 and Mac 10.10 - 11.3. If you are seeking any simple way to burn WMV to Blu ray on Mac, try this free Bluray burner software.
Step 2: Select the module 'Creator' and set the mode as 'Blu-ray Creator'
DVDFab 12 includes many modules, where Bluray DVD burner is just one of them. Besides acting as a Blu ray burning software, it is also a DVD burning software and UHD burning software. So in order to use it as a Blu-ray software, you need to set the mode as 'Blu-ray Creator'.
Step 3: Load your file
Click the '+' icon and import your videos to this Blu ray burning software. DVDFab Blu-ray Creator can create Blu ray discs in batches, so you can load as many videos as possible with this best Blu ray burner.
Step 4: Customize with 'Advanced Settings' and 'Menu Settings'
There are two important options on the main interface of this Blu-ray burner software: Advanced Settings and Menu Settings.
Click 'Advanced Settings' and you will be able to set the name of your file, output the videos to a BD 50, BD 25 1080P/i, BD 9 1080P/I, BD 720P, bd 5 1080 0/i, or a BD 5 720P. If you desire video resolution, there is also a 4K Blu-ray burner free to use.
Click 'Menu Settings' and you will be able to choose a menu background.
If you are not satisfied with the menu templates offered by this Blu ray burning software, you can also click 'Browse' to upload your favorite as Bluray covers and click 'OK'.
And then, there are options for you to add widgets, text, etc., to your Blu-ray files.
Next, click the option of 'Set Up' and set the Audio and Subtitles for your burned Blu-ray videos.
Step 5: Set the output destination and click 'Start'
You can save your burned videos to a Blu-ray disc, folder, or ISO file. After that, click 'Start' to make the best Blu discs like BD 25 or BD 50.
As the best Blu ray creator, DVDFab Blu-ray Creator also enables you to add external subtitles. When adding an external subtitle track, a preview window will pop out for you to synchronize the subtitles with the video. At the bottom of the main interface of this top Blue ray recorder for PC, you can choose how many copies you want to burn. How long does it take to burn videos to Blu-ray? This Blu ray burning software for Windows and Mac works 30x faster than other top burn software, so you will be able to enjoy your burned videos as soon as possible.
DVDFab Blu-ray Creator, a powerful and professional Blu-ray burning software, is used for burning various videos including HD camcorder videos, iPhone MOV videos, common SD videos, etc., to blank Blu-ray disc/folder/ISO file.
(2) Express Burn
  • Blu ray burning software Windows 10
  • Convert AVI/MPG/VOB to Blu-ray discs
  • Burn DVD and Blu ray discs
  • Free to create a CD but paid to burn videos to DVD
  • Allow you to create menus and chapters
  • Easy to use
Express Burn is another quick and easy-to-use Blu-ray burning software program. It can burn AVI, MPG, VOB and all DirectShow supported video formats to Blu-ray discs. Its advanced feature lies in that it allows you to create and manage chapters on Blu-ray disc. As a Bluray recording software, it is not as versatile as DVDFab in burning Blu-ray, but it contains the features of Audio CD recording, Video DVD authoring and Data CD/DVD/Blu-ray writing. So it’s ok to choose Express Burn if you still want to burn CD and DVD other than enjoying the basic Blu-ray burning feature. Express Burn only supports the Windows system. Though it works as free Blu ray burning software, but the free version can only be used to burn normal CDs. For advanced functions, you need to buy this Blue ray burning softwawre.
(3) ImgBurn
  • Blu ray burning software Windows 10/8/7
  • Burn audio CDs, video DVDs, and blu-rays
  • Portable Blu ray burner
  • Not updated since 2013
  • Free to use and user-friendly
ImgBurn is 100% free Blu ray burning software and a lightweight CD/DVD/HD DVD/Blu-ray burning application. It can burn various files and image files to Blu-ray discs at ease. This best DVD blu ray burning software also can create playable Blu-ray discs from BDAV/BDMV folder, and that’s what makes it stand out from a lot of free Blu-ray burners. As a matter of fact, ImgBurn is a Blu-ray burner with many other advanced options. In addition to Blu-ray, this top Blu ray burner also can burn CD/DVD/HD DVD and create playable DVD. It also has the ability to create an image file from files on a computer or network and read a disc to an image file. ImgBurn is a powerful disc burning software but it only works on the Windows system.
(4) Leawo Blu-ray Creator
  • Burn videos to Blu-ray, DVD and ISO
  • Various disc menus and templated models
  • Offer a built-in video editing tool
  • Burn AVI/MOV/MKV/WMV/MP4 to Blu-ray
Leawo Blu-ray Creator is a relatively comprehensive Blu-ray burning software program that can burn and convert videos in various formats to playable Blu-ray and ISO image files. There are many menu templates in Leawo Blu-ray Creator, and you can DIY your menu according to your preferences. There is also an option for you to burn common 2D video to 3D Blu-ray. The built-in video editor in Leawo Blu ray creator allows you to trim, crop or add watermark to your video. The Blu-ray burning software is available for both Windows and Mac systems, but it is not totally free Blu ray burning software.
(5) BurnAware
  • Create Blu-ray, DVD, CD, and M-Disc
  • Extract audio tracks and recover data
  • Burn data across several discs
  • Clean interface and simple-to-use
BurnAware is a full-fledged Blu-ray burning program with a clean and beautiful interface. The interface of this best Blu ray burner is straightforward and intuitive, and all its functions and features are clearly classified into four sections, namely Data, Multimedia, Disc Images, and Utilities. You can easily find the tool you want to use. With BurnAware, you can create and burn standard/bootable Data Blu-rays and make BDMV discs that can be played on a Blu-ray player. Its copy feature is also a highlighted part which enables you to copy disc to ISO image and copy Blu-ray disc to disc. CD and DVD are supported by this Windows disc burner. Want to know how to burn a Blu ray disc on Windows 10? Go to the product page of this top burn software.
(6) Ashampoo Burning Studio
  • Blu ray burner on Windows 7/8/10
  • Copy and burn movies to Blu-ray easily
  • Allow you select templates, menus and thems
  • Burn MP4 to Blu-ray
  • Work fast to create a Blu-ray disc
Ashampoo is a handy Windows Blu-ray burning program. It can create Data Blu-ray discs and Blu-ray discs with autostart capability. It also has the ability to create Video Blu-ray from the prepared folder and get disc images from Blu-ray discs. As one of the top burn software, it includes an advanced function for you to create modified copies of Blu-ray discs. Ashampoo Burning Studio provides step-by-step instruction when you make a Blu-ray burning, but it lacks some customization options for you to customize your Blu-ray. You can also use this best Blu ray burner to burn CDs and DVDs. However, this Blue ray recorder for PC is not free Blu ray burning software. If you want to know how to burn a Blu ray disc on Windows 10, resort to the step-by-step guideline on its official website.
(7) CDBurnerXP
  • Blu ray burning software on Windows 7
  • Free Blu ray burner to burn Blu-rays
  • Support disc spanning burning
  • Suitable for beginners to use
Don’t be fooled by the CD in its name, CDBurnerXP in fact is a free Blu ray burning software program for disc lovers. All kinds of CDs/DVDs/Blu-rays are supported by this burning tool. With CDBurnerXP, you can burn any data to Blu-ray discs and make a copy of a Data Blu-ray. The burning software also allows you to burn ISO files to discs, create ISO images from discs. The major functions of this Windows burner are all presented in its main interface, so novice users can find the right tool easily, or they can go to its official website to find the detailed burning steps.
(8) DVDFab Blu-ray Copy
  • Blu ray burner available on Windows 10/8.1/8/7 and macOS 10.10 - 11.3
  • Copy Blu-ray movies to a blank Blu-ray disc
  • Offer five Blu-ray burning service: Full Disc, Main Movie, Customize, Merge, Clone/Burn
  • Free to use up to 30 days with watermark
  • Works fast to burn Blu-ray movies to a disc
As one of the leading blu ray copy software, DVDFab Blu-ray Copy can copy and burn data/bootable Blu-rays and standard Blu-ray movies, including 3D Blu-ray movies, to blank Blu-ray discs. This powerful Blu-ray burning software provides 5 burning modes, namely Full Disc, Main Movie, Customize, Merge and Clone/Burn, which can fulfill your various burning needs.
Full Disc: copy all the contents of the Blu-ray disc, ISO file, or folder in a 1:1 ratio with lossless quality.
Main Movie: Copy the main titles (usually with longest time duration) as ISO file or folder, or onto a blank Blu-ray disc.
Clone/Burn: burn data and bootable Blu-ray disc onto a blank disc, or compress Blu-ray, say BD-50, to smaller disc size, BD-25.
Customize: customize your Blu-ray movie the way you like, meaning you can choose the titles, chapters, audio tracks, and subtitles you want, and customize your own menu.
As we all know, commercial Blu-ray titles contain many protections that stop you from burning and copying the movies for personal use. DVDFab Blu-ray Copy, one of the top burn software, comes with a built-in Decrypter that can circumvent nearly all Blu-ray protections and remove all region codes. Note that you can remove Blu-ray protections with this Blu-ray burning software free program only for legally personal use.
In fact, DVDFab Blu ray burner software not only works on Blu-ray discs, but also can deal with Blu-ray folder/ISO files. This blue ray burning software is powerful enough to burn any Blu-ray disc/folder/ISO file to Blu-ray disc/folder/ISO file. Moreover, it also can burn Blu-ray to DVD/AVCHD disc (BD 5 or BD 9).
DVDFab Blu-ray Copy
DVDFab Blu-ray Copy is the first full-featured Blu-ray copier/burner/cloner to copy a Blu-ray, 3D included, to any Blu-ray/DVD disc or to your hard drive with just one or a few clicks.
Though so many advanced features are included, DVDFab Blu-ray Copy is easy to use. If you want to use the basic burning feature, you only need to insert the Blu-ray disc or drag & drop the Blu-ray folder/ISO file to the main interface, choose the burning mode, and click the Start button. The Blu-ray burning software is a good choice both for novice and veteran users. Due to its support of the newest hardware acceleration technology, DVDFab Blu-ray surpasses many competitors in burning Blu-ray at flash speed. DVDFab Blu-ray Copy is available for both Windows and Mac systems, with a 30-day free trial, virtually the best free Blu-ray burning software.
How to Use DVDFab Blu ray Burning Software
As to how to use this best Blu-ray burner software, please refer to the following simple guideline.
Step 1: Launch DVDFab Blu-ray Copy and load Blu-ray source
Free download and run the best free Blu ray burning software. Insert Blu-ray disc into the external optical drive on PC or Mac. Alternatively, search Blu-ray ISO file or folder from the local drive. For simplicity, just drag & drop the Blu-ray file onto the main UI. As the best Blu ray burner, it is virus-free and safe-to-use.
Step 2: Choose one Copy mode and customize the output Blu-ray
Click the Advanced Settings button to set parameters for the output Blu-ray. You can choose output size as per the Blu-ray file. Besides, tab the Choose Other Titles, you can customize output file as well. Just act according to your actual needs using the options offered in the best Blu ray burner.
Step 3:  Start to copy Blu-ray
Once done, click the 'Start' button to copy Blu-ray or burn Blu-ray to a blank disc. The whole copy or burning process will be shortened considerably since this Blu ray burning software free applies GPU Hardware acceleration technologies.
Besides internal Blu-ray burning software, there are also some external Blu ray burners. Here, let me introduce some of it for your reference.
(9) ASUS Blu-ray Burner
  • An external Blu ray burner
  • Support 128 GB data storage in a disc
  • 16X video to Blu-ray writing speed
  • Burn a BD-R (XL, TL, DL, QL) and M-disc
  • Provide a free UHD software register code
If you don’t install any free Blu ray burning software on your PC, there are also external Blu ray burner available such as ASUS. You can find this Blu ray burner best buy. And the current price for this hardware is $169.99. After an order, it can be shipped from the United States as soon as possible.
(10) LG Blu-ray Burner
  • Also an external Blu ray burning software
  • Protect and store data reliably
  • Offer BDXL ultimate capacity
Similar to that, this is another LG Blu ray burner for your choice. You can pick the best Blu ray burner hardware here.
Now the features and functions of top 10 best Blu-ray burners have been listed above, so do you have any idea which one you shall choose? If you are still undecided, my advice is to try each or several of them yourself. DVDFab Blu-ray Copy and Blu-ray Creator should be on the top of your try list as the best free Blu-ray burning software, because they are powerful enough and provide a 30-day free trial. So act now!
By the way, if you aim to upscale video while ripping Blu-ray to videos that can be played on various devices, DVDFab Enlarger AI will help you achieve this aim. It will work seamlessly with Blu-ray Ripper module to rip Blu-ray to 4K videos with better image quality.
Hot topics on DVD/Blu-ray/UHD:
Top 15 Free DVD Rippers to Fix Copy Protection (Professional and Best)
Download MKV Movies - Play MKV - Convert MKV to MP4
Top 8 Best Blu-ray Burning Software 2021
4 Best ISO Makers 2021: How to Make ISO File from DVD Free
6 Best DVD Menu Creators to Make DVD Movie Menus
Top 8 Best Free DVD Decrypter for Windows & macOS
SDR vs HDR: What You Should Know
DVD to Digital: How to Upload a DVD to YouTube
Top 11 Best Free DVD Makers
1. Convert Blu-rays to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract Blu-ray audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab DVD Copy
Copy DVDs as ISOs/folders or to blank discs in 1:1 lossless quality
DVDFab DVD Ripper
Rip and convert DVDs to 600+ video/audio formats for mobile play
DVDFab Blu-ray Ripper
Rip and convert Blu-rays to various video/audio formats for mobile play
