How to Burn DVD on Mac Free and Easily
2021-07-26 23:51:56     Posted by Starry
2115
Summary: This post aims to offer you some simple, free and professional solutions to burn DVD Mac from multiple videos, ISO files, movies, music, and slideshows with desirable quality and fast speed. Read on to take your pick.
Want to burn DVD Mac from videos, movies, music, or images so that you can play on home player?How do I burn a movie to a DVD on a Mac? How do I burn photos to a DVD on Mac? How do I burn DVDs for free on Mac?...’ If you are looking the right answers to these questions, you have come to the right place. For most beginners but keen on disc collection, it is imperative to master how to burn a playable DVD on Mac so as to retain pastime memories, make systematic tutorials or business presentations. This post has everything you need as to how to burn DVDs on Mac to play in DVD player with desired features. Check it right now!
PART 1: Best Solution to Burn DVD Mac with Professional Menu Templates
To burn DVD Mac with professional-look DVD menu templates and customized options, you are advised to choose DVDFab DVD Creator since it is capable of making quality DVDs for professional use. Now let’s take a look at its peerless features that make it stand out from the rest Mac burning DVD programs.
Available on: Win & Mac, 30-day free trial
Features:
⚬ Burn DVD on Mac and Windows from videos of all formats
⚬ Built-in menu templates with premium designs to make your DVD professional
⚬ Customized options to make your menu unique and feature-rich
⚬ Burn DVD Mac with fast conversion speed supported by GPU hardware acceleration
⚬ Output lossless standard DVDs playable on home players or media software
Actions speak louder than words. Now let’s get down to figuring out how to burn a DVD on a Mac with amazing quality and lightning-fast speed beyond imagination!
Burn Video to DVD Mac with DVDFab DVD Creator
Step 1: Download and launch DVDFab 11, and load video source
After free download and pure installation, move to the left pane and select DVD Creator from the mode switcher when the program runs. Afterwards, add video source or simply drag & drop it onto the main UI.
Note that DVD Creator is integrated into DVDFab 11 together with other modules for the sake of better user experience. Meanwhile, you can import videos of diverse formats such as MKV, MP4, AVI, M2TS, TS, MOV, WMV, WMA, 3GP, FLV, M4V, VOB, etc. That means this DVD burning software does not just works for Mac burning MP4 to DVD. You can burn all kinds of videos to DVD instead.
Step 2: Customize output DVD via Advanced Settings and Menu Settings
After loading video files, hit the Advanced Settings to choose output DVD size: DVD-9 (once-sided, double-layer recordable with a capacity of 8.5G) or DVD-5 (one-sided, single-layer that holds 4.7G data storage), Menu Properties including TV Standard and Aspect Ratio, and Playback Mode. Besides, you can add external subtitles to your movie DVD to be made. Besides, all DVD disc formats are supported and customized options will help you burn video DVD Mac professionally.
Then click the Menu Settings button to set personalized DVD menu for better playback control experience. Here, you are allowed to change the elements or widgets inside the menu templates, add your own image or text to the menu interface, even adjust text size, font, color, or make it italic or underlined. Thus, feel free to customize your main menu, buttons, theme selection menus, thus burning movies to DVD Mac to create a cinema-like viewing experience. What the final DVD menu will look like is totally at your disposal.
Mind that these menu templates will be updated regularly to meet diverse needs.
Step 3: Start to burn DVD Mac with Turbo Speed
Insert a blank DVD disc (whose size depends on the size of video files to be burned) into the optical drive. If you have no blank disc at hand, just save the output DVD as ISO file or folder for later burning. Then tab the Start button to launch the Mac burning DVD task. Supported by GPU hardware acceleration technologies, the whole process of burning DVD on Mac will be considerably shortened to the fullest. By the way, you can check the real-time burning progress on the status display bar.
How to burn MP4 to DVD Mac fast and well? Refer to the above guideline. With this free DVD burning Mac and Win program, you can burn video DVD Mac or burn movies to DVD Mac for better playback on home player like Xbox One or media player software like DVDFab Player 6.
PART 2: How to Burn a DVD on a Mac with Simple Features
There might be times when you mean to burn ISO files, playlist of favorite songs, or monumental photos to DVD Mac for latter playback. In this regard, you can turn to the following solutions to meet your diverse needs.
Burn ISO to DVD Mac with Finder/Disk Utility
As we know, Finder is the default file manager and graphical user interface shell applied on macOS (Macintosh operating systems) designed to launch other apps and manages files, disks and network volumes. Also, it can be used as a free DVD burner Mac tool. How do I burn an ISO to a DVD Mac in Finder? A piece of cake! First, select a disk image file from the Mac Finder, click File menu and choose Burn Disk Image (Name) to Disc, then insert a blank DVD into the external optical drive or SuperDrive. Finally, click Burn button to wait for the output DVD disc.
For macOS user, do not forget to make the best out of Disk Utility (a system utility used to perform disk and disk volume-related tasks on macOS) to burn ISO to DVD Mac. However, both Finder and Disk Utility can only work as a basic Mac burning ISO to DVD tool except for lacking additional features such as menu templates and customization.
Burn Video DVD Mac with iDVD
iDVD is a popular macOS Mavericks (version 10.9) DVD burner from Apple, dedicated to authoring and burning movies, songs, and photos to a professional-quality DVD with animated menus, buttons, selections when it works with an Apple SuperDrive or other compatible third-party DVD burner. When you want to share your movies and photo slideshows with your families or friends, iDVD comes in handy to burn movie to DVD Mac and burn slideshow to DVD Mac efficiently.
How to burn a movie to DVD Mac with simple steps? Just open iDVD, choose Magic iDVD, choose a theme and the movie you want to burn from the iLife Media Browser. Magic iDVD can automatically creates a new project covering main menu and buttons. Here you can choose from 150+ Apple-designed themes in widescreen and standard format. What worth mentioning is that you can create OneStep DVD from footage shot by camcorders. Hence, feel at ease to make your DVD masterpiece based on its feature-rich customized options of this free DVD burning Mac program. Nevertheless, all its stylish menu features can be well embodied on macOS.
Burn Slideshow to DVD Mac with SimplyBurns
SimplyBurns is an open-source Mac app with simple interface that enables users to burn media files such as music, photos or data into a CD or DVD. Meanwhile, it can store data on a disk or rip disk on the hard disk of Mac store. Inside this Mac burning DVD app, audio and data project, backup mode, burning image mode, disc ripping mode are available to burn slideshow to DVD Mac or rip DVD disc to hard drive. One more word, this free burning DVD Mac program is easy-to-use for novice users.
Burn Music to DVD Mac with iTunes
iTunes is one of the most widely used applications developed by Apple, which collects and catalogs thousands of songs, TV shows, podcasts, and movies. However, not all users are familiar with its free and quick burning feature that enables you to burn music CD or DVD in iTunes.
Then how to burn music to DVD Mac free and easily? Open iTunes, create a new playlist or select the existing playlist. Go to File menu, select Burn Playlist to Disc, followed by Burn Settings reminding you to choose Speed and Data DVD. Remember to tick Use Sound Check. Then hit Burn, you will be asked to enter a blank DVD. You can see the burning progress and wait for the final disc.
PART 3: FAQS on Burning DVD on Mac
After knowing how to burn DVD on Mac with different Mac burning DVD programs, it’s necessary to have a quick look at below Frequently Asked Questions.
Can you burn a DVD from iMovie?
iMovie, another exclusive program offered by Apple, enables you to create and edit digital movies or videos, freeware popular among all macOS and iOS users. Yet if you want to burn DVD Mac from videos with iMovie, it will let you down. Each performs its own functions. Turn to iDVD or Finder for better results.
What is the best DVD burner for Mac?
As demonstrated above, the title of best burning DVD Mac program shall be given to DVDFab DVD Creator since it allows users to burn all sorts of videos, downloaded from YouTube, captured from smartphones, shot by camcorders, or other DV devices, into standard DVD formats (discs, ISO files or folders) with unexpected speed and quality. Above all, you can make DVD menu of your own style.
How to upscale DVD quality?
There might be occasions when you are unhappy with the Mac burned DVD discs due to low resolution or poor quality. Here comes a good solution to convert DVD to Blu-ray quality for better viewing experience on home Blu-ray player or media software. In this case, an AI-driven video enhancer will work seamlessly with DVD to Blu-ray Converter to upgrade DVD to Blu ray.
Final Thought
Now you might have gained a better understanding of the above-listed Mac burning DVD programs and got the hang of how to burn a DVD on a Mac playable on home player or media player software. Just take your pick from the recommended options. When it comes to burning DVD on Mac with desirable results, DVDFab DVD Creator will always be your first choice thanks to its turbo-speed conversion process and optimal output quality.
1. Convert DVDs to AAC, MP3, MP4, MKV, AVI, and etc.
2. Support all the popular smartphones, tablets, and etc.
3. Freely customize the output audio & video parameters.
You May Need Other Tools
DVDFab Player 6 Ultra
World's best versatile 4K media player that can play all DVDs, (4K) Blu-rays, HEVC and regular videos
DVDFab Enlarger AI
Most pwoerful AI video enhacer able to upscale video from 480p to 1080p, or from 1080p to 4k
DVDFab DVD to Blu-ray Converter
Convert DVDs to standard Blu-ray format saved on computer HDD as a Blu-ray ISO file/folder or burnt onto a blank BD 50/25/9/5 disc
