How to Rip and Convert DVD to VOB with DVD to VOB Ripper?
2020-05-28 04:26:44
Portable devices such as smartphone, tablet, Macbook cannot play DVD discs, because they do not have an optical drive or cannot be connected with a DVD player. So if you want to watch your DVD movies on your portable devices, you can convert DVD to VOB to play the movie with media player softwares on your devices. DVDFab can rip or convert DVD to VOB effortlessly. Now let's have a look at the conversion process.
How to Rip and Convert DVD to VOB with DVD to VOB Ripper: Step 1 > Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to VOB with DVD to VOB Ripper: Step 2 > Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to VOB with DVD to VOB Ripper: Step 3 > Navigate to the profile library on the top left corner of the main interface and choose Forma t > Video  > VOB.
How to Rip and Convert DVD to VOB with DVD to VOB Ripper: Step 4 > Now you can choose the titles, chapters, audio tracks and subtitles, define the names of the titles, and do advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
How to Rip and Convert DVD to VOB with DVD to VOB Ripper: Step 5 > Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to get more information about DVDFab DVD Ripper, please go to https://www.dvdfab.cn/dvd-ripper.htm.
