How to Copy DVD to Hard Drive Free and Fast 2021
2021-03-30 23:21:11
Summary: This article aims to demonstrate how to copy DVD to computer with DVDFab DVD Copy for better playback instead of being played on standalone disc player.
Want to copy DVD to computer for better storage or flexible playback with DVD player software? Preserving physical DVD discs means space issues and a risk of being damaged and scratched. To resolve this problem, why not copy DVD to computer or hard drive for lasting preservation? If you are wondering ‘How to Copy DVD to My Computer’ at fast speed and high quality, you will find the best solution from this recommended DVD copy software, DVDFab DVD Copy.
Quick Navigation
1. Why You Need to Copy DVD to Computer
2. Features of DVDFab DVD Copy Software
3. How to Copy DVD to Computer Fast and Well
4. Conclusion
First, DVD discs are easy to scratch and fail to be played due to improper preservation and mechanical breakdown. Although commercial DVDs are expected to last over 50 years, they must be compressed on quality media and kept in a cool, dark, and dry place. Normally, heat, humidity, and improper handling can reduce the life span of optical discs, which makes it difficult for personal users to keep discs for so long. Second, your computer may fail to read DVD discs, even power up due to mechanical failure. In this case, you cannot playback DVD on computer, let alone copying DVDs to computer, unless you watch a DVD disc on a standalone player. Anyway, you can also copy DVD to a hard drive to avoid computer disorder. After all, the hard drive is also deemed as the safest way to copy DVD to DVD for better storage as long as you use it appropriately.
Before mastering how to copy DVD to computer, it’s essential to giving you a full picture of the striking features of this DVD copier which has been well received by countless disc lovers.
• Copy DVD to blank DVD disc, as ISO file or DVD folder
• 6 copy modes: Full Disc, Main Movie, Clone/Burn, Merge, Split and Customize
• Flexible customized settings for output size, audio, and subtitle languages
• Output spotless and lossless quality content
• Available on Windows & Mac, 30-day free trial
Apparently, you need DVD copy software to copy DVD to computer. Faced with numerous DVD copy tools, how to choose the best one really means a lot! This guideline shows you how to copy DVD to computer with DVDFab DVD Copy, the best DVD copy software worth your full trial.
Step 1: Launch DVD copy software and load DVD source
Download and install this free DVD copy software on a trial basis to copy DVD to computer, but you shall endure limited features upon trial expires. Note that this DVD copier is integrated into DVDFab 12 so that you can access various modules. Then insert a DVD disc into the optical drive of your computer. Alternatively, press the ‘+Add’ button to load ISO file or DVD folder, or simply drag & drop the file onto ‘+’ area.
Step 2: Select one copy mode and customize DVD output
Move to the left panel to select one copy mode from the mode switcher. You can copy DVD to DVD with 1:1 ratio (Full Disc), compress DVD to save storage space, copy main movie title (Main Movie), or copy any chapters as you desire (Customize) from the source. Besides, you can split one DVD-9 disc into two DVD-5 (Split) discs, or merge multiple DVDs into one DVD (Merge). What’s more, you can copy DVD to a blank DVD disc (Burn), or clone DVD with 1:1 ratio (Clone) to gain lossless output DVD. Hence, you can copy DVD with different options: copy DVD-9 to DVD-5, DVD-9 to DVD-9, DVD-5 to DVD-5, and DVD-5 to DVD-9. Note that from DVD-9 to DVD-5, you will get output content inferior to the original in video image due to compression.
Now tab the Wrench icon (designed for Advanced Settings) to identify output size: DVD-5 or DVD-9. Do not forget to tick ‘Copy DVD-Video (Video_TS folder)’, otherwise, you will get a blank disc or empty folder. Aside from copying DVD to computer, you can copy DVD to a hard drive via connecting your hard drive to the USB slot on your computer. Then set the file directory to save the output DVD content on a blank disc, as ISO file or DVD folder on computer HDD or on your external hard drive.
When you copy DVD to computer via Full Disc or Main Movie, the source DVD might contain Cinavia watermark. If so, you need a Cinavia-free tool DVD Cinavia Removal to avoid suddenly muted playback before copying DVD to computer with this DVD copy software. The same goes for copying DVD to hard drive.
Step 3: Start to copy DVD to computer
Once done, tab the ‘Start’ button to copy the DVD. This DVD copying software will show real-time progress on the bar while copying DVD to DVD. In the meantime, you can stop copying DVD whenever you like, or just set your PC to auto shut down, exit program, hibernate or do nothing when the DVD copy task is done. Once finished, you can watch the output DVD disc/ISO file/folder with DVDFab Player 6 on Windows or Mac, which will bring you a stunning visual experience.
The above 3 simple steps are how to copy DVD to computer with DVDFab DVD Copy. By the way, if you want to download DVD to the computer, you can download your desired ISO file or DVD folder online and save them on a computer or hard drive. However, the best solution concerning how to download DVD to the computer is to turn to DVD Ripper, a sort of disc ripping tool designed to rip and convert DVD to videos/audios of all popular formats that can be played on all kinds of mobile devices.
In a nutshell, next time when you wonder how to copy DVD to computer, do not forget to read through this simple guideline. With this recommended best DVD copy software, you will be able to copy DVD to computer with high quality and blazing fast speed.
